imaq mask on U16 image
Hello!
Can someone please explain to me the following:
I can use IMAQ  mask on every image type except for the U16. Why is that?
Please see the trivial example below.
I am using Labview 8.6 professional.
Thank you and best regards!
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(2,668 Views)
Your Vision Development Module seems to be too old. Support for U16 was covered partially in early versions. Try version 2010 or latest Vision 2011 - for me IMAQ Mask works with U16 image. Both VDM 2010 and 2011 are compatible with LabVIEW 8.6.
Andrey.
(2,655 Views)
Thank you for the answer.
Guess i will use signed types or try the newer version.
Best regards
(2,651 Views)
