imaq usb grab and save avi format
I installed the ni_imaq_usb_installer_86.exe and I tried to run this VI (Grab and Save USB LabVIEW 86.vi) but it not run. The error was Error -1074395986 occurred at IMAQ AVI Create Invalid file format. What should I suposed to do?
David Fiorillo
(6,231 Views)
What is the i/o name u r using?
(6,214 Views)
Muks,
The name is Laptop Integrated Webcam
David Fiorillo
(6,212 Views)
Hi David,
I coud reproduce your error only leaving the field "AVI Path" empty, in the VI "Grab and Save USB LabVIEW 86.vi", after I fill a path like "C:\test.avi", it worked without problems. Did you had filled this field?
Osvaldo Santos
(6,167 Views)
Osvaldo,
I tried to insert the path and filename in the field but didn't work.
Tentei sim, inserir o caminho e nome do arquivo no campo mas não funcionou
regards,
David
David Fiorillo
(6,161 Views)
Accepted by topic author dfiorillo
Hi David,
This error is occurring before start the acquision, the LabVIEW does not have permission to create a file in this folder. So it does not start the acquisition. Try to put another path, for example the desktop path.
I attached the file without the save instruction, so you can test your cam support, after it you can resolve the problem with save file.
Osvaldo Santos
(6,133 Views)
You're right. Thanks. Now is working. The Vista is not giving permission for Labview to save files in the root.
David Fiorillo
(6,122 Views)
