imaqdx property nodes
Hi
I´m using a GigE camera (DFK23GM021) and im trying to set for example the brightness.
I would like to know how the property nodes work and how i can acquire the attribute names/strings i need to put into the nodes.
Thanks in advance.
(3,082 Views)
Use the control and connect property node and you will see the options
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,069 Views)
i´m quite new to Labview and have no idea what you are talking about, could you upload a vi and/or explain it in detail please?
(3,064 Views)
Instead create one control and create property node and connect and check by yourself.
Try this if you didnt succedded then I will let you know
--Ranjeet
(3,031 Views)
Accepted by topic author Eumel2
the camera im using doesnt support the imaqdx property nodes, instead i have to use Active X nodes for it to work.
(3,021 Views)
