imaqdx session control
I am using a IMAQdx session control to select on of two cameras in my system
but the control does not show the drop down list of cameras although correctly configured and visible in MAX.
I am using LV8.6.1. and ImaqDx 3.8 under WIN XP.
Does anyone knows the reason for that behavior?
Thanks.
Message 1 of 8
(3,968 Views)
Do both cameras show up under IMAQdx in MAX?
Christian
Message 2 of 8
(3,955 Views)
Christian
Message 3 of 8
(3,953 Views)
Christian
Message 4 of 8
(3,952 Views)
Christian,
yes both cameras are listed.
Message 5 of 8
(3,952 Views)
Yes, but my question was if both cameras show up under IMAQdx in MAX. Or is one camera under IMAQ?
Can you provide a screenshoot of MAX.
Christian
Message 6 of 8
(3,950 Views)
Sorry for my late response.
Here is the screenshot. Both cameras (cam0 / cam5) are listed under IMAQdx.
Regards Ralph
Message 7 of 8
(3,939 Views)
So when you open a new VI and place "IMAQdx Open Camera.vi" at the blockdiagram, then rightclick the "Session In" Input and select "Create Indicator" or "Create Constant" from the context menue, you just see the default value cam0 and you cannot select any other?
Please test it the way I described.
Christian
Message 8 of 8
(3,937 Views)
