imbedded vs stand alone execution time
I have a vi that does some digital and analog I/O with a 6024E NI board. When I run it stand-alone, it takes about 20-30ms to execute. But when I run it imbedded as a subvi, it takes almost a full second to execute. Any ideas why?
(2,947 Views)
what is the top level vi doing? Could you post an example?
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,947 Views)
The top level vi is doing several things in 2 parallel loops. In one loop, the data gathered by the vi in question is written to a DataSocket. In the other loop, I'm using the IMAQ vi's to acquire an image from a framegrabber and place some overlays onto the picture. Using the tick count vi and a few sequence structures, I've isolated the execution time of the vi in question, and from the time LV enters this subVI until it exits is the 1 second I mentioned.
(2,947 Views)
Have you tried change the subvi's preferred executing system to "Data Acquisition"?
VI Properties -> Execution.
Joe
(2,947 Views)
