implementation of GMSK modulation in Labview
 I am new in labview. I want to Implement GMSK Transceiver in labview .kindly suggest how can i implement Gaussian MSK. kindly suggest any document or VI. your help in this regard is highly appreciated. thanks in Advance.
Message 1 of 11
(6,244 Views)
how to make a GMSK modulation and demodulation  in labview?
or change the msk modulation in GMSK?
Message 2 of 11
(6,219 Views)
The NI Modulation toolkit supports GMSK modulation schemes and can be used to build or demodulate data.  You can download the Modulation Toolkit here:
https://www.ni.com/en/support/downloads/software-products/download.modulation-toolkit.html
There are a few examples for MSK, I believe all of them include the option of using a Gaussian filter.
Jon F.
Technical Support Engineer
Message 3 of 11
(6,198 Views)
thanks Jon  for you help.
can you talk about the pulse shaping filter in MSK examples.please see the screen shot and reply me...
Message 4 of 11
(6,193 Views)
There is an article white paper available from NI:
https://www.ni.com/de-de/innovations/white-papers/06/pulse-shape-filtering-in-communications-systems.html
Message 5 of 11
(6,181 Views)
hi,
is there any extra filter is used to mod or demod the GMSK or  MSK example in modualtion tool kit 15 is available is used as a gmsk.
i am little bit confuse in this...
i am using labview 2015, and modulation tool kit 15
operating system windows 7 ultimate
Message 6 of 11
(6,173 Views)
My understanding of GMSK is that it is very similar to regular MSK except that the data stream is sent through a Gaussian pulse shaping filter to increase spectral performance.  So when choosing Gaussian for the filter type in the Mod toolkit example, you are applying this filter and thus implementing GMSK.
Jon F.
Message 7 of 11
(6,163 Views)
thanks Air Frantz,
according to your opinion there is no other filter is used,just select filter type from none to Gaussian to implement the GMSK and receive GMSK signal ???
Message 8 of 11
(6,133 Views)
That is what I understand about the modulation scheme.  I've not worked with GMSK specifically, but I've found many documents online which explain the scheme in detail.  This was a helpful one for me:
http://sss-mag.com/pdf/gmsk_tut.pdf
Jon F.
Message 9 of 11
(6,101 Views)
hello everyone,
i want to implement MSK transmitter and Receiver, for this i transmit a signal and Receiver on USRP 2920, but the garbage bits are received and if   i dont transmitt data but  i transmit data also a contentiously changing bits are received and BER is 1. whats the issue
your help in the regards is highly appreciated,
thanks in Advance.
Message 10 of 11
(6,084 Views)
