import bmp
dear sir,
 i am using labview 8.2. and i am having some question regarding pictures.
  Now my application is that i want to import some pictures like logos, circuit diagrams from word document. Is it posiible if yes please help me for this
regards
falgandha mohire
(3,765 Views)
Hi falgandha mohire,
if you want static pictures you can insert them with drag and drop. If you want to work with pictures, load them while the program is running, then use the picture functions.
Mike
(3,759 Views)
dear sir,
 thanks a lot
i want a static picture which is already present in my word file. Now when program starts i will selecte the path for the file and i want that the picture indicator will automatically display the picture which is pesent in word file.
regards
falgandha mohire
(3,757 Views)
and if the word file change, then it is another picture?? In this case you have to use activeX to get the picture from the word file and then the picture functions to show it in your indicator.
Mike
Message Edited by MikeS81 on 07-21-2008 07:29 AM
(3,755 Views)
dear sir
please give me the codes for this if possible
thaks a lot
(3,752 Views)
                                  R u asking "how do i read an image file and dispaly?" R u intrested in bringing ur company logo(for ex) in your front panel?U can directly copy paste. Do u want to read a image present in a doc that will keep changing?
(3,734 Views)
see the attached axample code.
Mike
(3,728 Views)
