import different arrays from different sheets of an excel file
Hi
The task is to get multiple arrays(different) that are in different sheets of an excel file. I have tried using the report generation toolkit, Excel get worksheet, Excel get data functions. but the problem there is that the Excel get worksheet function requires a report input. but i only have an excel file as input and i cant feed that. Is there any alternative to this?
(2,447 Views)
Accepted by topic author Mayur_VIenthusiast
Just create a report using New Report.  Wire in the path to your Excel file as the "template".  Also, be sure to dispose of the report when you are done with it.
(2,437 Views)
