import pictures to block diagram
Leonitas,
I am also not understanding your reqest.
Please take some time to draw some pictures or screen shots that illustrate what you want to do.
"The first step in solving a problem is defining what the problem is"
So help us help you by posting some picture of what you want,
PLEASE,
Ben
Message 11 of 15
(1,401 Views)
If you would look at (Using custom controls. vi) you would see that there is a picture from the ladder and a picture of human on it. I want to see how I could bring pictures like these into the labviews front panel and be able to create a terminal for it in the block diagram so I could do the coding
Sam
Message 12 of 15
(1,377 Views)
In reply #40 of this thread I posted an example using a picture ring.
You right-click on the picture ring and choose Advanced >>> Customize
Once in the Control editor, go to edit mode and right click on the picture ring and selcted "import image".
Then you repeat the import using Import after.
When you are done you will have a mini film srip you can control from your code.
This is what one frame of that example looks like.
Ben
Message 13 of 15
(1,359 Views)
Please note in (using custom controls .vi) there is no ring and picture frame around the ladder and the human. In the human and ladder picture the human is locked to the ladder in one .
Following your suggestion to bring the pictures as an individual does not allow me to overlap separate pictures into the one ring, as you see in the bottom corner that  the  hand and alien are not on the same frame
Please show me how to overcome this problem.
Message 14 of 15
(1,336 Views)
That looks like they imported graphics to replace the slider with a man and used allder in the background.
See tst's Nugget to learn how to do that.
Ben
Message 15 of 15
(1,316 Views)
