importing cvi instrument driver and c string pointer
I want to export some plain C functions ro Labview VI. To do that I created fp file. When I imported this in LV7.1 it worked fine but when I Use LabVIEW Interface Generator for LabWindows-CVI version 1.1 I don't get string as output. I always get integer as output even if my prototype says it is string.
int STDCALL ReadLine_(int handle, char line_buffer[], int max_no_of_bytes)
      return ReadLine(handle, line_buffer, max_no_of_bytes);
In above example, When it creates VI it shows line_buffer an integer array. It should be string.
I have attached both LV7.1 and LV8.0 cases.
In LV 7.1 I have imported this from Tools\Instrumentation\Import CVI instr driver
In LV8.0 I used LabVIEW Interface Generator for LabWindows-CVI version 1.1.
My source files/DLL are same for both of these cases.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
Message 11 of 14
(761 Views)
Hello again Sheetal,
Have you opened the VI in 8 to see what the CLF node looks like?  The function returns a char[] which LabVIEW probably reads as a number.  I would change the CLF node in LabVIEW to have that parameter passed as ‘adapt to type’ and wire in a string to see if that fixes it up.  Also, if you can create a small FP instrument with one function which can replicate this problem myself or someone else in the community might be able to further assist.
Travis M
LabVIEW R&D
Message 12 of 14
(749 Views)
Ok. I have attached my complete project.
My function is
char * STDCALL my_function(char *char_pointer, char char_array[], int *int_pointer);
In LV 8 my return value is integer instead of string.
In LV7.1 it is string.
I do not get any output for char_pointer and int_pointer.
Thanks.
CVI 2010
LabVIEW 2011 SP1
Message 13 of 14
(740 Views)
Good afternoon Sheetal,
I apologize for the delay in the response to your last post.  I was able to replicate exactly what you are talking about.  I filed a corrective action request on it for R&D to examine (3Z9EN63A).  For now, the way to workaround these difficulties is to manually modify the CLF call created for the function to return a C string, or to continue use of 7.1 and save the VI drivers in 8.0.  I apologize for this; please let me know if you have any further question.
Thanks, and I do apologize for any inconvenience caused as a result of this behavior.
Travis M
LabVIEW R&D
Message 14 of 14
(724 Views)
