impuls from constant true boolean
I'm trying to make an impuls (100ms) from a constant true boolean on the rising edge.
Similar to the mechanical action of a push button, but now controlled from a on/off button.
So when a certain boolean get's "High" or true, this impuls also get's true, but only 100ms and than back false.
This should happen everytime when the input boolean has a rising edge.
I've already did some research, but did not find a similar solution yet.
Thx
Tom
(3,807 Views)
Accepted by topic author Rockyenco
Hi Rocky,
play with the ElapsedTime function…
(3,801 Views)
Hi GerdW,
Thx, i was able to fix my problem.
See attached file.
It was so simple.....
(3,786 Views)
