03-28-2013 12:58 PM
In a graph is it possible to fill base line to both negative infinity and positive infinity?
03-28-2013 02:56 PM
Could you explain what you are imagining this to look like? If the plot color was red and you could fill this to both -infinity and +infinity then the whole graph would be colored red...
If you meant for the colors to be different an easy work around is to the set either the -infinity or +infinity and then color the background of the graph to the other color:
