in place element structure waveform convert units
How can i get the convert units to work within a In Place Element Structure with Add Waveform Unbundle/Bundle Elements.  It says "You've connected numeric data types that have incompatible units."
(3,359 Views)
Accepted by topic author Regulator
Share your code please.
Cheers
(3,357 Views)
Waveform Datatypes do not work that way  Y[ ] is always stored "unitless" in the base unit of the units displayed in a Waveform constant on waveform control.  For instance:
OK I tried to find an example and created a waveform with Y[ ] in Gs with a value of 1 then changed the unit to mm and found that the m^2 component of Gs was preserved--- Don't use units they have many "Features" that are less than adequately documented.
(3,317 Views)
