inckuding run time engine in installer
I 'd like to know if it is possible to include the LV run time engine using application builder under LV 7.1.1 in an installer file, and if it is where should I find  the options in the application builder parameters.
olivier
(2,583 Views)
Hi olivier,
yes, you can. In the app builder options, Installer Settings, click on the Advanced... button. The option to install the run-time engine should be on by default; you may select which additional components of the RTE should be installed (e.g. the Analyze Vis).
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,567 Views)
