include an start up graphic in exe file
Hi
I wanna create an exe file from my code. I would like when user start using of my executable file, an special graphic be appeared in screen before my GUI to be loaded. for example when we start Labview a picture as below will be loaded first, include the company name,product name and so on. I am searching a way for doing something like this. I appreciate any help.
start up graphic
(2,846 Views)
Accepted by topic author farashi
Create a SubVI where you place the picture you want to show at the frontpanel. When starting the application run the SubVI for a few seconds.
Limit the frontpanels size to the picture and under the VI Properties>Window Appearence modify the VI to don't show the menu, scrollbars, and so on.
Christian
(2,842 Views)
Splashscreen_by_Time.vi displays a splash screen using the specified image file.  The image remains for the specified amount of time.
Splashscreen_by_Boolean leaves the image up until a specified boolean goes true.
(2,784 Views)
