include cin tools
I am building dll (dll.dll) in LabVIEW 2011 to be called somewhere else. Its dll.h file includes reference to extcode.h from LabVIEW\cintools.
If there is no LabVIEW on target machine, there are no cintools, they are not installed with run-time engine
Without extcode.h and linked fundtypes.h file types are not recognized (including int32_t and etc) and it can not build functions prototype based on header file automatically (matlab).
Do I need only type definitions from cintools, specific for each compiler?
Any correct solution?
Including cintools folder manually next to dll does not seem to be a right solution
Mainly it will be called from Matlab or LabVIEW, possible solution is to make a simplified extcode.h with simple type definitions for Matlab only..
(4,444 Views)
I've created DLLs that were called from C++ with no header file problems. Perhaps this is a MATLAB issue?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,417 Views)
