incompatible image size in AVI Write
I am trying to write a AVI file from grabbed image ROI window which changes on the fly.
When the size changes, the Labview gives the error of
"Error -1074396074 occurred at IMAQ AVI Write Frame
  Incompatible image size.
IMAQ Vision:  (Hex 0xBFF60456) Incompatible image size."
What is causing the error?
Any way to work around this?
Message Edited by mehmetg on 07-10-2006 03:12 PM
(4,085 Views)
It seems IMAQ doesn't support change image size.
In AVI format, you've to create another stream if you change the image size I think.
You might have to create multiple AVIs for differenct size.
You can stich them together afterwards.
George Zou
George Zou
(4,073 Views)
