incorrect array replacement
Hi I have got a problem regarding the replacement of data in the array.
At first it seems working but the index (0,0) is missing like "V1"
Please advise.
Clement
(3,043 Views)
Your listbox display is scrolled away from default.
One solution: Right-click ... show vertical scrollbar... scroll home ... hide vertical scrollbar. 🙂
(3,041 Views)
Another solution: programmatically set "top left visible cell" to [0,0] via the same property node.
Message Edited by altenbach on 01-31-2008 07:43 PM
(3,040 Views)
It's there. You're just not displaying row 1 of the listbox. Enable the vertical scrollbar and move to the top.
(3,039 Views)
Hi Altenbach and Dennis.
It's weird.
Thanks.
 Clement
(3,027 Views)
