incorrect terminal name for "get variant attributes" (bug?)
According to the help, the output named "values" should change its name to "value" once we wire a name.
This does not seem to be the case (See tip strip in image below) as tested in 2013 and 2014..
(2,911 Views)
In LabVIEW 2013 it changes to value if only the name input is wired. Once you wire the default value, it switches back to values. 50% is true 🙂
(2,860 Views)
Interesting...
(2,858 Views)
