increase array size of column in array
how to increase array size of column???i have two output data from two sql statement. my 1st sql array size is 7.  i want to pass the data sql2 after the last data in 1st sql..is it possible to me to do that??
(3,974 Views)
Let's assume you have two different 1D arrays and want to append the second array to the first array, creating a 1D array with a lenght corresponding to the sum of the sizes of the input arrays.
You do this using "built array" from the array palette. You need to right-click it and select "concatenate array" for the desired outcome. Try it. 🙂
If this is not the right answer, you need to tell us more details....
(3,973 Views)
Hi Alten, I encounter this problem recently NI-488 Table Error [Error Code: 20] "Configuration token not found" ...
Any solution for this problem ?
May I know in detail ? Because I'm new to this and needed guidance 🙂 thank you so much
(3,672 Views)
Hi alk...,
so you entered a ~4 year old thread with a totally different topic?
Please start a new thread and give more details for your problem! What is a "NI488 Table Error"? Show your VI and maybe pics of the FP!
(3,669 Views)
