increase digits of precision in saving data to file
In the attached VI written in Labview 8.5, can you tell me how I can save the data in the array to 6 decimal places?  From the code that I have posted, I can only get up to 4 decimal places.
Thanks for your help.
hiNi.
(2,569 Views)
Accepted by topic author hiNI
It looks like using 801 as the input gives you nice numbers. Try changing it to 800 for instance and you get a larger number of digits in the spreadsheet (you may need to expand the cells to see it all though). Crunch some of the numbers manually (for instance using a calculator) and see if you get the same results for the first few points.
(2,565 Views)
