increase number of input
Hi there,
 I am starting new project which is kind of data acquistion program and I need little guidance. Let me explain what I am doing.
I want to create program to accept data from TCP-IP, RS485, RS232 and analog input(4-20mAmp). User should able to choose any of these.
for example, user can choose to read data from TCP-Ip and RS485 at same time OR maybe he can choose to read data from 4 TCP-IP devices and 3 RS485 devices at same time.
and I need "ADD" button to add another device. after adding new device, program should able to read 5 TCP-IP device (as per above example and if user selects to add device which uses TCP-IP protocol).
Is this even possible in labview? if yes then how??
Thank you so much for help
(1,166 Views)
I use the Start Asynchronous Call to launch VIs that do their specific job, such as monitoring a RS-232 port.
You could also use Actor Framework if you want to go the OOP heavy route.
(1,137 Views)
hey,
Thank you for reply.
Okay, I will try your suggestion.
(1,104 Views)
