increase vertical size of control in front panel
hey,
i want to increase vertical height of numeric controls in front panel but while doin so i dont want to increase distance between increment and decrement buttons of control.i tried to increase the height but using property node.but i find after certain limit the distance starts increasing. i have attached my file. if this cannot be done. suggest me some way to increase or decrease the controller value by using separate buttons of large size like shown in next file.
vanashree
Message 1 of 11
(3,837 Views)
Vanashree,
you have to create your custom control having the correct size and component placement.
You can create a custom control by right-click on the default control and select Advanced >> Customize...
Please refer to the help for how to use the customization tool.
Norbert
Norbert
Expert: Geometry
Message 2 of 11
(3,828 Views)
hey..i right clicked on the num control>>advanced>>customize, the num control was opened in separate window.what do i do next?.is customization a toolkit?or just a setting?
Message 3 of 11
(3,788 Views)
is there any other option?
Message 4 of 11
(3,784 Views)
Exactly what problems are you having with the control editor? Have you read the help? Have you put it into edit mode?
Message 5 of 11
(3,770 Views)
Accepted by topic author vanashree
USe the "system spin control", it scales much nicer.
This is how it look in Windows 8.1:
(NOTE: the exact look of system controls will depend on the OS and desktop theme)
Message 6 of 11
(3,758 Views)
you are just superb...i tried spin control thanks a lot..this is for my masters project and  i am really glad...thankyou so much..:)
Message 7 of 11
(3,741 Views)
hey
Message 8 of 11
(3,735 Views)
hey
Message 9 of 11
(3,720 Views)
Offtopic arduino discussion continues here
Message 10 of 11
(3,708 Views)
