increment HOW TO help
You were given the shift register hint and you ignored it.  Listen to the advice given.  Take the Labview tutorial online.  These are very very basic beginner things that should not be asked here.
20759iF3996CEED4B68E98
- tbob
Inventor of the WORM Global
Message 11 of 52
(2,344 Views)
Many thanks @tbob, now I only need delay for each increasment for 1 second.
Example:
0...0s
1...+1s
2...2s(1s+1s)
3...3s(1s+1s+1s)
MANY thanks
_________________________
Rookie; LV 2011 on WIN 7
Message 12 of 52
(2,334 Views)
I can see that this is leading to us doing all your work.  Look for the delay function yourself.  It is not hard to find.  Put some effort into your work before you ask us to do it for you.
- tbob
Message 13 of 52
(2,325 Views)
Well I do it like this:
Output goes to agilent 66xx series(configure.vi). I want to set voltage from 9 to 16 V, for each "V" one second delay. I add "Time delay", but the output VOltage goes 9V then wait 7 seconds and jump to 16...
any ideas?
Message 14 of 52
(2,289 Views)
You must put the Wait and the output to the Agilent into the for loop.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
Message 15 of 52
(2,273 Views)
Well I tried but with no success: try delay also timer...
Also I have problem, because, when I stop, it doesn't go from the begginin but it's stay at 16...
Message 16 of 52
(2,264 Views)
Here 🙂
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 17 of 52
(2,262 Views)
Can you please make it for 8.5 version? Many thanks
Message 18 of 52
(2,258 Views)
Here you go 🙂
Even
Topro AS
Norway
Message 19 of 52
(2,248 Views)
Well this is not good, I need automatic counter from 9-16 with 1 second delay for each  value. For example:
9...start
10..1 second
11...2 second
Many thanks
Message 20 of 52
(2,232 Views)
