increment decrement color
Is it possible to change the color programmatically of the increment/decrement buttons of a numeric control ?
I couldn’t find the property..
Kind regards,
(2,608 Views)
Apparently not, but you can hide them and create 2 boolean controls which will serve as your inc\dec buttons. You will need to write some code to control that (an event structure with a couple of cases). You can group the 3 controls to make them stay together.
___________________
Try to take over the world!
(2,599 Views)
