increment the number with date/time string. when ever the next date come's it should reset again with initial number
 i want to store the number of records in a file. Every time when ever i run the program the record will be incremented well i using forloop with count value 1 as a constant .in the for loop i am using autoincrement with the  feedback node . to view the number i have attached the indicatator .the number will be increment every time . i am using number to time time stamp  that is connected to get date/time string. from that we can view the date string and time string . so , my issue is when ever i close the code again it is coming with intial value . i should get from that number only where ever i close the code . after the date completed again it should come from intial value . i am attaching the code so that u guys can solve my problem.
Message 1 of 8
(3,909 Views)
Hi dow,
next time when you attach "code" you should attach a VI or a snippet or a real picture (PNG preferred). Using a DOC file is considered "bad behaviour"!
- You don't need a FOR loop in your code.
- You should not use STOP in your code.
- You should THINK DATAFLOW: Setting the "record" indicator to it's default value is nonsense when it is displaying data coming from feedback node!
- You have to change your FBN initialization to fit your needs: it's nonsense to init it once the VI is started the first time…
Message 2 of 8
(3,887 Views)
our requirement is daily we have to run 200 to 300 electrical boards in ni-zigs ...... we want to see how many boards we are doing  per day. for that purpose
->i am using the string indicatator in fornt panel to see my electrical board record.
->i am using feedback node from my indicator so that next time the value will increase from the previous value.
->well, other thing i should not use  for loop, but, i want every time  constant value as 1 when ever i want to open my code default it should come from 1.  thats why i have used for loop.does it make sense or not you should suggest me.
..........by the way i am begginer in ni .
Message 3 of 8
(3,875 Views)
Are you storing your test results anywhere?  I'd be using a database, so an SQL query would easily get me the number of units I've tested in a day.
Jim
Message 4 of 8
(3,862 Views)
hi jim,
the total test results will be storing in files..........well i have created one file.............by  concatenating all indiviual strings like one for total result,one string for storing records , one string number of records that i am storing.........i think there is no need of sql query here...........
if u have idea of storing results using sql query .........can u show me the sample
Message 5 of 8
(3,856 Views)
I'm not clear on how you're storing your data.  Could you post an example?
Jim
Message 6 of 8
(3,842 Views)
here you can see.......the file path in case structure in that i have included my requirement of increment the number
-> if the case is true then it goes in ok file path and the no of records string will pass in the file by seeing these code u will get clarity
my requirement is the number of records should increase ........ whnever the program runs...that i made it. by the next day again it should begain with the intial value.........that is my requirement. i hope u understand .
Message 7 of 8
(3,829 Views)
-> if the case is true then it goes in ok file path and the no of records string will pass in the file by seeing these code u will get the clarity
suggest me how can i use the  intial  value .......
Message 8 of 8
(3,822 Views)
