index 1D array of dynamic data
HI.
I have 2 dynamic data wires. Basicaly, i want to access each element of two, with one function (module) in a moment.
I use build array, and with a probe i can see for wire 1 (elements : x1,y1,z1,....), and for wire 2 (elements: x2,y2,z2,....).
Now, i want to use a function (module) good enough to select for example y2 from wire2  and  z1 from wire1.
thanks.
(3,457 Views)
Do you have any code? Do you have any data something that we can look at to try and help? What have you tried so far?
Tim
GHSP
(3,445 Views)
do you have multiple 1D arrays?
(3,436 Views)
Accepted by topic author dsasorin
hei , i got it !!
i used 3 build array  and 1 index 2D array. Innitialy, i put merge signals instead of build array, so i was stucked there.
Thanks for being around.
Here is a vi. My project is more complex, so i made an example for you. (LV 2010)
Could it be done simplier ?
(3,424 Views)
Yes it could be done simpler..
Have a look at the snipet below.  No need for a while loop if you wire TRUE constant to the loop condition.
Why not simply have a 2D array Control..?
(3,411 Views)
