indexing a set of data to take an average
hi,
I am measuring the resistance vs temperature. For this, 10 times resistance are measured and average of this data is plotted vs temperature which is also averaged.
I couldn't do that unfortunately. How can I do that?
thanks
(2,504 Views)
You are sending two points to the graph: the average of the two heaters and the running average of the voltage over current.
Also, you are only averaging 2 elements instead of 10. What's in the other frames of the stacked sequence?
You are only showing us 30% of the code, and a lot of what we see is dead code without apparent purpose. Why don't you attach your VI instead?
Righ now you are showing a running average. Do you want to acquire 10 points in one shot and only graph the average once ber 10 measurments?
Sorry, it is not really clear what you want. It is even unclear what you don't want. 😉
(2,488 Views)
I have attached vi '. There are 2 cycle to check. But I need 10.
Best.
(2,486 Views)
