indicators retain old data plus new data
running LabVIEW 8.2.1 on windows XP. I display a 2D array of string in a table, with the ability to view a set of parameters for a given data point, and the ability to view NEXT or PREVIOUS data points (sets).
The initial display (point zero) displays correctly, when I choose NEXT all the data correctly updates HOWEVER two cells (R0C1, R2C1) also display the original data (cell R0C1 shows both values of RPM: 1500 and 6000 superimposed, both numbers in the same cell). It is odd that it is only 2 cells, but I have been using LabVIEW for 12 years and I didn't even know it was possible to show two strings in one cell???
I don't see how this could be a code issue(?) maybe some known bug??
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(3,182 Views)
Can you show a simple example that demonstrates the problem?
(3,173 Views)
not sure what was causing it, but what I did was write an empty array to the table prior to each update and the problem went away.
thanx,
lmd2
cell: 516.819.9711
(3,166 Views)
This issue is also in 8.6.1 - I have a new thread here.
I've posted it to tech support.
It's definitely a bug.
Steve Bird
Culverson.com
LinkedIn
(2,896 Views)
