information from one tab to the next
Hello!!!
I was hoping someone would help me do this, I'm using tab control in my vi but I need to use information generated in the first page of the tab in another tab. Well, what I'm trying to ask is how can I pass info from one tab to the next??
(3,032 Views)
For this example, you don't need to do another more complicated than what is shown below. I really don't see why the tab control needs to be wired up to a case statement like you did.
Message Edited by Dennis Knutson on 11-13-2008 01:26 PM
(3,029 Views)
Thank you, but this is actually a simplifyed version of my program.
My actual vi is more complicated. So can anyone tell me how to do this??
(3,013 Views)
How much more complicated. If you can't post an example that actually demonstrates what the problem is, try you best to describe it. If you have a case statement wired to the tab control, explain why you think you need to do such a thing. My guess is no matter what, there is no compelling need and that you are just making things much more complicated than it needs to be. Remember, a tab control is primarily used to organize front panel controls and indicators and is not normally required to be wired to anything on the block diagram.
(3,004 Views)
