information on web based control applications
I am trying to set up web based applications on Labview. I wanted to know if
Labview supports Internet Information Server (IIS) or Apache Server instead
of its in built Labview Web Server. I am trying to setup applications using
Active Server pages (ASP). It would be great if I could some info in this
regard.
(2,717 Views)
LabVIEW really does not have any interfaces to IIS or Apache. The only thing that I could suggest is build your LabVIEW application into a .dll and call it from another language that does support either of these two servers. You will need to get the application builder and LV6i.
Doug
(2,717 Views)
