infrared temperature sensor
You need to look up the specifications for your sensor.  It must have some sort of datasheet.  It must show some sort of voltage to temperature conversion.  Whether it is a linear conversion, non-linear, or perhaps some sort of lookup table, the datasheet will give you the details.
Message 11 of 13
(907 Views)
Thank you very much for your reply.
it is a relationship between voltage and emissivity
U in V  = 0.0 - 0.5 - ......... - 4.5 - 5.0
Emissivity = 0.1 - 0.2 ........- 1.0 - 1.1
These are the relation in the datasheet, but I do not know how can I convert emissivity to temperature.
Message 12 of 13
(902 Views)
Create 2 1-D arrays of the data.
Use the function called Threshold 1-D array to search for the index of the voltage in the voltage array.  Then use that index with Interpolate 1-D array to look up the corresponding emissivity.
Message 13 of 13
(885 Views)
