Dear
I would like to ask several things regarding to application builder and installer.
Some user defined *.ini file for initial configuration will be used in my LV application.
Please don't complex it with an application *.ini file.
1. I failed to include the user defined *.ini file to application builder.
How to define the folder correctly and include in application builder?
My main vi (c:\app) is in different location with sub vi (c:\app\subvi). The ini file will be loaded to one of sub vi.
2. Some ini files should be located in c:\windows system folder. How to include in application folder.
3. Would you please how to optimize (for fast execution) the application before or after building by application builder?
Thank you in advance.
Lee
메시지가 07-31-2007 09:12 PM에 labmaster에 의해 편집되었음
