initial condition in CD parametric time response (control design)
CD parametric time response calculates the output of system when a step input excites it, and the initial conditions are the initial values the parametric response uses. But there is a miscalculation in the taking into account of the initial conditions.
(2,482 Views)
You need to give us more information about what you are trying to do, with which tool and what the problem you are experiencing. With this information you will probably find someone in this community that can help.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,469 Views)
Effectively, could you please be more specific about your request ?
With more informations we could help you.
Best regards
Alexandre D
NIF
(2,453 Views)
