initialiser graphe deroulant a plusieur tracés empilées
salut,
francais :je veut initialiser un graphe déroulant qui affiche plusieurs courbes et les tracés de ce sont empilées (pas superposées)
                   vous pouvez voir la pièce jointe
english: i want to reset the waveform chart that it displays many curves(graphs) and their lines are stacked (not superposed)
                  see the attached piece
  merci
  TNX
(2,607 Views)
You're on the English section so please post in English. The same goes for the title of your post.
Then, you didn't explain what is your problem so we cannot help you for now.
You'll find in attachment a VI which show you how having two signals in a waveform chart properly.
If you want, you can explain with more details what you would like to do but I strongly recommand you to try to find some tutorials which will help you to progress.
Jérémy C.
NI France
(2,571 Views)
hello Jérémy C.
i couldnt open your attachment because i use the version 2011,but i found the solution,thak you.
I have a new problem : i want to plot the result of the exponential structure but i don't obtain the real exponential curve
do you any idea?
(2,562 Views)
Here the VI saved in 2011.
For a new question, please create a new post. Don't hesitate to look on the other forums. You could find your answers or example which could help you.
Jérémy C.
NI France
(2,546 Views)
