initialize DIO-96 failure -10007
Sheesssh!
You could have just said: "Load any version VISA driver. There arn't any incompatibilities with the versions of MAX or Instrument drivers that I know of."
Message 11 of 14
(911 Views)
Chill out.
All along you were talking about DAQ drivers.  And the decision was DAQmx vs. traditional DAQ.  Dennis told you what you needed to do.
1.  Load the traditional DAQ drivers to work with the old code
2.  Load the DAQmx drivers and rewrite your code to use them.
He gave you the options and you always felt the need to argue the opposite point or just weren't listening to what he said.
Then suddenly at the last minute you switch to talking about VISA drivers which have nothing to do with DAQ drivers!
Message 12 of 14
(906 Views)
Sorry.  Don't worry about the problem, I'm sure it will get fixed.  Thanks very much for you r help.
Message 13 of 14
(901 Views)
Hello Mike,
This is xxxx from National Instruments. Here is a discussion forum that
discussed the compatibility issue.
Error 10461 / 10008 @ DIO Port Config (Legacy, lvdaq.dll)
http://forums.ni.com/ni/board/message?board.id=170&message.id=424836&req
uireLogin=False
If you have LabVIEW 7.1, you would need DAQmx 8.7.1
http://joule.ni.com/nidu/cds/view/p/id/965/lang/en
If you have LabVIEW 7.1.1, you would need DAQmx 8.7.2
http://joule.ni.com/nidu/cds/view/p/id/1087/lang/en
Here is a link on how to configure NI-DAQ driver in MAX
http://ftp.ni.com/support/softlib/multifunction_daq/traditionalnidaq/7.4
.4/nidaq_readme_traditional.html#Configuring%20Traditional%20NI-DAQ
Let me know if you are still having issue with this.
Thank you
xxxxxxxxxxxxxxx
Message 14 of 14
(866 Views)
