initialize array and reinput output
I hope the title isn't confusing...
Basically I want to know the following.  I have an array (A_0) of decimals.  I want my vi to have a button that has some function (f) to cut out a portion of that array and return the new sub-array (A_1).  But I want that output to become the new input for that cutting function.  So that I can cut out multiple portions of the array, one step at a time.
f(A_0) = A_1 => f(A_1) = A_2 => ... => f(A_n-1) = A_n
Writing that last line I realize I'll need some kind of for loop.
But I can't seem to figure out how to rewire the output of the function as a new input.
(3,135 Views)
You'll need to use shift registers to pass the data from one iteration to the next. Right-click on the for/while loop border and add shift register. Then wire your function's ouput to the right-hand shift register, and the left-hand shift register to your function's input.
Message Edited by Sima on 06-15-2006 12:18 PM
(3,130 Views)
Use a shift register to transfer the output from one iteration of the loop to the input of the next.
Lynn
(3,127 Views)
