input variables into combo box
is there a way to add an array of 1 d strings to a combo box? thank you if you have time for an example that would be great.
(2,844 Views)
You just need to use a property node ( right click on the control>> create>> property node) of that combo box and select its property as either 'strings[ ]' or 'strings[ ] and values[ ]'
Now, pass corresponding 1D array to it
See attached pic for more information
Regards
Dev
(2,839 Views)
perfect thank you
(2,819 Views)
