inputs into matlab script in labview
i am having a problem with the matlab script. i have the labview 7.1 and matlab 7.01 on my computer. i am trying to send a 2D array into a matlab script and in the script i want to plot the matrix. i am setting the input as a real matrix but the script does nothing. is i am setteing the matrix inside the script (not as input) the script plots the matrix .
my question is : how do i set the input correctly, so i could use the script.
(3,080 Views)
There is a bug that only allows complex numbers into the Matlab script. This bug is fixed when you upgrade to 7.1.1. If you can't do this convert your array into a complex array and feed it into the node.
Randall Pursley
(3,072 Views)
Hi eran,
There is a new DLL available for Matlab 7.0 that resolves the complex datatype input issue. Either you can download the new DLL from KB 300A6NDT or upgrade to LabVIEW 7.1.1 where the issue has been resolved.
How Can I Resolve MATLAB and Xmath Script Node Issues in LabVIEW?
Hope this helps!
Kileen
(3,057 Views)
