insert 2D array columns into 2D array (with different size)
Arrrggggfffff , I didn't know "concatenate inputs" ..... since long time use labview
.. we learn everyday !
Ludovic
Message 11 of 13
(815 Views)
GerdW wrote:
@PAnand:
Why do you need to convert an array to a cluster to simply INDEX the elements?
Back in (very!) ancient times, when index array was not resizable, this method  took less diagram space. Nowadays it is convoluted. 😉
Message 12 of 13
(809 Views)
llavy@ems-ch.com wrote:
I like last solution (little function & fewer buffer) ,
Don't twist my words around. I said that last solution had more buffer allocations than the earlier version:
"My earlier version has significantly fewer buffer allocations, so it might be more efficient for large arrays (not tested)..."
Message 13 of 13
(807 Views)
