insert a symbol in the tree control
Hi , I use a tree control in a VI. I insert a symbol before the child item1, in the picture one. When the mouse double clicks, I want the symbol to change in the picture tow. Thanks.
(4,888 Views)
picture in the attachment.
(4,887 Views)
You can use the Active item->Symbol-property to change the icon.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,854 Views)
You'll probably want to check the current symbol.  If it is already a 5...change it to 4....and vice-versa.
aputman
(4,833 Views)
There is a great example here on tree controls including changing the symbol for open and closed states.
https://decibel.ni.com/content/docs/DOC-25645
Mike
(4,812 Views)
thanks
(4,801 Views)
