insert array into colums
i have a global devices..
2d array..
i want to check the first element
copy SN from row 1 - 65
copy gain = 7 from row 1 - 65
set kPT0, kPT1, t37, mT, CalVal to ZERO (O)
Message Edited by krispiekream on 03-28-2008 05:16 PM
Krispiekream
Message 1 of 16
(4,816 Views)
Hi krispiekream,
from where to where do you want to copy the S/N and the gain?
For example you can index the complete column you need and run through a for loop.
Mike
Message 2 of 16
(4,809 Views)
from another array
Krispiekream
Message 3 of 16
(4,807 Views)
Hi krispiekream,
you could initialize an array with the size you need and fill it with "0". All other field you could overwrite by using the array functions.
Mike
Message 4 of 16
(4,798 Views)
lets say i have an array of 2d,
590232, 60, 7, 2322, 23232, 23232
590934, 60, 7, 2324, 23242, 23232
how do i take the second row (590934), column 2                 (7) of the array?
i want to get out
7
Krispiekream
Message 5 of 16
(4,796 Views)
i think that might work
Krispiekream
Message 6 of 16
(4,795 Views)
no, i already did that..hmm...can you show me a diagram??
Krispiekream
Message 7 of 16
(4,792 Views)
does it matter how you initialized the array?
Message Edited by krispiekream on 03-28-2008 06:14 PM
Krispiekream
Message 8 of 16
(4,789 Views)
it is only the "Index Array" function. And if you want to select more than a single element use the "Array Subset" function.
Mike
Message Edited by MikeS81 on 03-29-2008 12:15 AM
Message 9 of 16
(4,785 Views)
thats what i thought too..
i am always getting an error when i tried that..
something about..
Message Edited by krispiekream on 03-28-2008 06:18 PM
Krispiekream
Message 10 of 16
(4,780 Views)
