insert cluster in array
I did something wrong
I try to build an array of xy location but it doesn't work!!! I have Labview 6.0
(3,102 Views)
If I understand correctly what you're trying to do, then I think you should be using the Insert Into Array function instead of the Replace Array Element function. Your initial array that you input via the shift register has only one element and the Replace Array Element function won't replace an element if it doesn't exist.
(3,102 Views)
Hi
You are using "Replace Array Element" instead of "Insert Array Element" Function.
I changed the "Replace..." with "Insert..." in both your True and False Cases. Moved the resultant Array Inside the While Loop.
The Modified VI is attached.
Mache
Good Luck!
Mache
(3,102 Views)
