insert data from text file to a database table
how can i transfer a specific text file data to a table in a database in labview....
for example this is a specific line of text file... i want each value to be inserted in a table of a database... means changing the text file record to database record..
abcxxx123;  name:john  adress:abc123  phn-no:123123
Message 1 of 8
(4,323 Views)
A response was already provided to you when you first asked this question: http://forums.ni.com/t5/LabVIEW/reading-data-from-text-file-and-saving-it-in-a-database-table/m-p/18... and again (http://forums.ni.com/t5/LabVIEW/reading-data-from-text-file-and-saving-it-in-a-database-table/m-p/18... and again (http://forums.ni.com/t5/LabVIEW/how-to-read-write-from-Access-database/m-p/1818275#M624324).
Have you researched the answer? Or do you think that asking the same question over and over again will magically provide a different answer?
Message 2 of 8
(4,314 Views)
read all my questions..all of them are different..if you can not give me answer...let others reply... what i asked in this post is totally different...
Message 3 of 8
(4,310 Views)
Use the database tool Import from text file, no LV needed.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 4 of 8
(4,306 Views)
can you show me by an example if possible....
Message 5 of 8
(4,301 Views)
They are all the same question, asked in different ways. That does not make them different questions. You want to update a database with some information. The information you provided is the same exact one in each of your questions. Originally you were reading this from a file. The source is irrelevant. If you want to use LabVIEW to talk to a database, you've been given the answer. If you have control of the database then you can use the database server's own tools to import data, as suggested by Yamaeda. Your call.
Message 6 of 8
(4,298 Views)
http://msdn.microsoft.com/en-us/library/hh212942(v=SQL.110).aspx
/Y
Qestit Systems
Message 7 of 8
(4,297 Views)
Look at your database server's documentation. If you're going to use the database server to do this, then this is no longer a LabVIEW question.
Message 8 of 8
(4,296 Views)
