insert graph in a document
   I have the report generation toolkit and I want to save many waveform graph in a Word document. I've done the test and 10 pictures make my file 1Mb big. It is very possible that for this application I have to save much more graph. That would imply a huge file and I don't want this. Is there any possibility to save some disk space?
Thanks in advance
(2,622 Views)
Mackemann,
I have faced (and still to resolve satisfactorily) a similar situation.
Pls find attached .zip of my thread on this. We handle the 1:1 printing using AutoCAD.
Other waveforms are sent to a word file by capturing an image of the control (the graph). It adds to the file size as you rightly pointed out.
I am not sure if this will work but how about sending the waveform data array to an exel file and then make excel convert it into a graph?
Let me know if you make any breakthrough on this problem.
Best,
Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
(2,614 Views)
