insert into array different sizes
  This is great...if you change to the build array you can insert as many 2D arrays into a 3d array with each 2 d array in its own page. However Labview pads the smaller arrays with zeroes. Is there a way to have Labview pad the smaller arrays with a "NAN"
Kaspar
Message 11 of 18
(2,438 Views)
LabVIEW is a full featured programming language, so everything is possible with a little bit of coding. Have you tried?
Message 12 of 18
(2,434 Views)
  Yes I did look at the "build array" and the help for it. I did not find anything that defines the "padding/filler" value for numeric arrays. Does anyone know where this is defined?
Kaspar
Message 13 of 18
(2,419 Views)
Hi Kaspar,
You know the row and/or column from which it is getting padded with 0s, right? Use Replace Array Subset function & wire the appropriate row & column indices to replace all unwanted 0s with NaN.
Hope it helps.
- Partha ( CLD until Oct 2027 🙂 )
Message 14 of 18
(2,410 Views)
     A comment related: I was looking for have 1d arrays with diferent size into a 1d array, i found that is only possible if you put 1d arrays at cluster and later inside of 1d array.
Best Regard,
Luis A. Mata C.
Ing. Electrónico
Whatsapp: +58-414-1985579
BBM Pin: 2B83E99A
Thanks: Kudos
Message 15 of 18
(2,325 Views)
I m not sure if I understood what you mean.
Insert Into Array function is used to Insert an element or N/N-1 dimension array into an N dimension array at a specified index.
Hope it helps.
Message 16 of 18
(2,322 Views)
Luis A. Mata C.
Ing. Electrónico
BBM Pin: 2B83E99A
Thanks: Kudos
Message 17 of 18
(2,315 Views)
@Luis_AM3C wrote:
     I was looking for have 1d arrays with diferent size into a 1d array...
Now I understood your requirement after seeing the code. Smiley Happy Yeah, this is possible only with cluster(s).
Thats why it is often said (in these forums) that a pcture is worth a 1000 words. Smiley Wink
Message 18 of 18
(2,309 Views)
