insert mathscript in sub vi labview
how to insert mathscript in labview? May I add the file .m in VI hierarchy?
because if I insert the mathscript, there is red cross or error symbol
I create the file .m from matlab, that's right?
Anyone can help me?
Thankyou
(3,062 Views)
Hi nihay,
what about reading the LabVIEW help for the MathScript node? (Especially the link to "user-defined functions"…)
You can use any text editor you like…
(3,053 Views)
I have been read  LabVIEW help for the MathScript node. File .m which I create has the same located with the others file .m
What is the cause of error because labview can not read the function hexToBinaryVector() ?
Even though, I run this programm in matlab is sucess
(3,040 Views)
Hi nihay,
Is this included in the search path as described in the LabVIEW help?
(3,032 Views)
