inserting columns from table into an 2D array
in the main VI i'm using event structures 😄
my Problem is still to insert the column values from the table into the combobox array
Message 11 of 13
(796 Views)
Accepted by topic author KKOCH
Part of the problem is you're trying to explain what you want by posting VIs that don't do what you want.
Looking at that test.vi, I can't figure out what you want to do. There's a table, an array and a few controls in a loop. There are a few comboboxes, and everything has a value.
I also wander what you consider the value of a combobox. A combobox is a string, and it's value is a string. The 'values' of a combobox that drop down are actually a property of the combobox (and can't be set individually in an array).
Message 12 of 13
(791 Views)
ok, i've understood that the idea with the array will not work.
I will try an other way.
thanks guys
Message 13 of 13
(767 Views)
