inserting images into indicators
hello,
i wanted to know if there is any way to insert images into indicators???
for example if iam having an indicatoor showing the speed of motor shaft is there any way by which i can have an image of a rotating shaft rotating at different speeds ( depend on some parameters back ground)  instead of just the numbers displaying the speed.
thanks in advance,
vijay
(2,795 Views)
Take a look at the attached example which uses a picture ring.
You can do various kinds of animation by using property nodes or the picture control, but that is already more complicated.
Also, have a look at this for some more examples.
___________________
Try to take over the world!
(2,788 Views)
