inserting matlab dll to labview
Hello all,
I am trying to insert a dll i created by matlab to a LV application.
I built a wrapper for it and it works if I have MATLAB installed at the computer.
I want it to wark where no MATLAB is installed.
I tryed installing the "matlab runtime component" but it does not help.
(2,793 Views)
That is a good matlab question.  Could it be that some of the functions you are using in your dll are actually inside other dlls?  That is, perhaps your dll is dependent on other dlls which are installed with the matlab development environment.
Another forum post has a recipe that worked for a customer, check out the following and see if there's anything new there that might help you:
Unfortunately, I am not familiar enough with the "guts" of matlab to speculate what other dlls or components you may be missing.
Thank you and best of luck!
JLS
Best,
JLS
Sixclear
(2,787 Views)
